Activity Forums Adobe After Effects Render with Layer Options??
  • Render with Layer Options??
    Posted by Mark Andrews on July 8, 2015 at 1:48 am
    There are often times when i need to render a comp multiple times with only some text being changed between renders. For example I will render the same graphic with different tags – “in theaters june 19”, “in theaters friday”, “in theaters tomorrow” and “now in theaters”.
    Right now what i do is create one comp that has all the titles in different layers. Then duplicate the comp x number of times and turn on a different text layer in each of the duplicates. Add them all the the render que and go to lunch.
    But is there an easier way? Does anyone know of a way to set up multiple renders of the same comp and toggle which layers will render each time? Maybe a script??
    Thanks in advance
    -Mark
    Derek Boettcher replied 11 years, 2 months ago 2 Members · 2 Replies
  • Mark Andrews
    July 8, 2015 at 4:04 am
    thanks.
    Ive never really considered taking it into an NLE before. I suppose it would save time in the end with the rendering also. In some instances I have other layers effecting the titles like particular or optical flares. But not always.
    I’m currious to try and see what Premiere could do for me.
    Thanks again.
  • Derek Boettcher
    July 8, 2015 at 2:54 pm
    I’m not so sure if you need to duplicate the comp, if you render out to media encoder, it will save a temp project with your adjustments saved to it. So you can set it all up with just one comp and it will save a separate temp every time. I haven’t tried that with 2015 yet, but it worked fine in cc2014
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
