Activity Forums VEGAS Pro Render with AC3
  • Render with AC3
    Posted by Rick Hughes on February 2, 2014 at 8:33 pm
    Advice seems to be that you should render as separate Elementary streams.
    I followed the doc .. Vegas rendering settings for a DVD
    https://www.custcenter.com/app/answers/detail/a_id/1105/
    I’m still a bit confused …
    I select Render Template “DVD Architect PAL video Stream”
    In customize template – there is an audio tab as part of this, and I can select it to ‘include audio’
    Then under ‘system’ tab, I have option to ‘save as elementary streams’ and then I could set it to AC3, bitrate I want etc.
    Is there any reason why I should not do it this way ? instead of running render twice and choosing separate audio template ?
    or is the Dolby Digital AC3 template going to use better audio encoder than Main Concept ?
    Rick Hughes replied 12 years, 7 months ago 2 Members · 2 Replies
  • John Rofrano
    February 3, 2014 at 5:22 pm
    [Rick Hughes] “In customize template – there is an audio tab as part of this, and I can select it to ‘include audio’ Then under ‘system’ tab, I have option to ‘save as elementary streams’ and then I could set it to AC3, bitrate I want etc.”
    That will produce a separate MPEG2 video and MPEG audio stream. It will not create AC3. That’s a different encoder.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rick Hughes
    February 4, 2014 at 5:43 pm
    Thanks … now rendered audio separately with AC3 template ….
