Activity › Forums › Sony Cameras › render trouble after converting xdcam to .mov for FCP
  • render trouble after converting xdcam to .mov for FCP
    Posted by Kate Chumley on July 20, 2009 at 4:11 pm
    Hi there,
    I’m editing footage from the EX1 in FCP 5 on a 2.4 Ghz Intel Core 2 Duo Macbookpro. I was unable to get XDCAM Transfer software to run correctly on this machine due to missing Apple Professional Codecs, so used another program (ffmpeg) to transfer the XDCAM mpegs to .mov files. In the process I down-converted (if that’s the right term) from 1920×1280 to 960×540 because I thought it might make work-flow and sending files easier later. Now I’m not so sure…
    These files (mpeg4, 23.98, square pixels) import easily into FCP, and load into my sequence, but require rendering (video and audio red line) and re-rendering when I try to play or work with them. I have been through all the FCP settings, adjusted the compression rates, made sure all the info between the clips and the sequences matches.
    Can anyone suggest something else I can do to get around this slow rendering problem (other than get another version of FCP, which I can’t afford right now), or do I need to do a whole new round of file conversion? If so, what can I do to avoid this problem?
    First time posting here. Hope I got all the details you need.
    Thank you,
    Kate
    Kate Chumley replied 17 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Craig Seeman
    July 20, 2009 at 4:49 pm
    Upgrade to FCP 6 (Final Cut Studio 2). When using $6000 camera one should spend the $500 or so to upgrade to the proper NLE to use it.
    If you MUST use ffmpeg your settings really depend on what your target is. If you need HD frame sizes that’s what you’ll have to do. I really don’t think this is the right way to go given the upgrade price to FCS2 and waisted time with workarounds for FCP5 (and time IS money).
  • Kate Chumley
    July 20, 2009 at 5:14 pm
    Thanks for the guidance. I see that this way is tedious and wrong…but for the moment it’s what I’ve got. Best,
    Kate
  • Michael Palmer
    July 20, 2009 at 7:28 pm
    Kate, How many clips/cards of material do you need converted? Where are you located? It would be very simple to find someone with the latest FCS2 and rewrap the files as Quicktimes then convert them using Mpeg Stream Clip to DVC Pro HD.
    Good Luck
    Michael Palmer
  • Clint Fleckenstein
    July 20, 2009 at 7:35 pm
    I think DVCProHD might be another one of those codecs you need FCS2 for. I tried to browse around some footage an agency sent us last week on an iMac that doesn’t have Studio installed, and it didn’t have the codec.
    I see your quandary, Kate…but you really do need to have Final Cut Studio 2. The only other option is going to be headache after headache after headache.
    Cf
  • Michael Palmer
    July 20, 2009 at 7:48 pm
    “I think DVCProHD might be another one of those codecs you need FCS2 for. ”
    No it was around in FC5, however she does need an NLE that supports the EX codec with this is her camera.
    Good Luck
    Michael Palmer
  • Kate Chumley
    July 20, 2009 at 8:28 pm
    That’s true and I’m in New York so I really should have thought of it (!). Thank you for the reply.
    Kate
  • Kate Chumley
    July 20, 2009 at 8:30 pm
    Thanks again to you both.
    Kate
