Activity › Forums › Maxon Cinema 4D › Render transparent materials with correct alpha
  • Render transparent materials with correct alpha
    Posted by Dave Suj on June 1, 2019 at 10:28 am
    Good evening, so I have a bunch of grass sprites cloned over some rocks in my scene which consist of 3d planes with a grass texture applied in the alpha. However if I choose to render the image out as an alpha for compositing I get the whole grass plane showing in my alpha, not just the material.
    Is there a way to tell cinema 4d to only render the alpha of the texture, not the actual plane object? Thanks!
    Brian Jones replied 7 years, 3 months ago 2 Members · 1 Reply
  • Brian Jones
    June 3, 2019 at 7:23 pm
    try increasing Render Settings/Options/Ray Depth
