Activity Forums Maxon Cinema 4D Render to Picture Viewer won’t work in scene with IvyGrower 1.2
  • Render to Picture Viewer won’t work in scene with IvyGrower 1.2
    Posted by Jared Flynn on January 12, 2013 at 11:12 pm
    Hi there,
    I’ve got an email in with Maxon Support right now but I wanted to ask the hive mind as well: I have a scene that relies heavily on several instances of the IvyGrower plugin. The ivy I’ve grown is configured NOT to render instances of leaves, and IS set to create IGSplines. I did this to allow animating the branches and leaves on per Twistedpoly’s technique found here: https://twistedpoly.com/?p=1527
    So here’s the problem. I can render in the viewport no problem– it looks great. But when I render to the Picture Viewer, nothing happens at all. The Picture Viewer opens up and just sits there idle– as though I’d picked it from the Window menu. If I delete all the ivy, the scene renders fine with what’s left.
    The problem seems to be limited to this one scene. I’ve even tried starting a fresh scene and merging everything into it, and the problem just persists.
    Is it just a question of project scale vs. processing power? My specs are in my signature and boy it doesn’t seem like that should be the problem. In fact, I don’t think it is; I can delete all but one instance of the ivys in my scene and it still won’t render to Picture Viewer.
    EDIT: After some more fiddling I’ve got the problem narrowed down to the IGSpline objects. If I delete those, the scene works fine. But if I understand how IvyGrower works in this case, removing the IGSplines will keep me from animating the ivy on, which is a real issue for me…
    Any advice? Other troubleshooting steps I could try out? I’ve got a client who’s quite enamored with the ivy idea so it’s really important I get this figured out.
    Thanks so much in advance!
    Jared Flynn
    Motion Graphics Designer
    https://be.net/jkinetic
    Supermicro SuperWorkstation 7047A-T
    Dual 8-core Xeon E5-2670 @ 2.6GHz
    64GB DDR3-1600 ECC/REG RAM
    PNY nVidia Quadro 4000
    Windows 7 Pro 64bit SP1
    Edward Intorcio replied 12 years, 5 months ago 3 Members · 4 Replies
  • Jennifer Estrada
    August 26, 2013 at 5:20 pm
    Hi Jared,
    I’m having the exact same problem. Did you find a “fix” for this issue?
    Thanks.
    Jenn
  • Jared Flynn
    August 26, 2013 at 6:39 pm
    Actually, unfortunately I never did get to the bottom of the problem. For my immediate needs I just made the whole rig editable (which removed all the IGSplines). This prevented me from animating the ivy properly, though, so I had to cheat it with some semi-clever camera work. I wish I had better news!
    If memory serves (I haven’t had occasion to work with Ivy Grower since that last project), I did have some luck animating the leaves at least. After making the IGSplines editable, I placed the leaves into a Fracture Object and used Plain Effectors to scale them up from nothing. Definitely not ideal, but hopefully it’s helpful! Cheers,
    Jared Flynn
  • Edward Intorcio
    March 26, 2014 at 11:31 pm
    Has anyone found a solution to this? I’m having the same problem. Using R14 on a floating liscence BTW.
    Thanks.
  • Edward Intorcio
    March 27, 2014 at 5:57 pm
    SOLUTION: While we couldn’t get the picture viewer to activate, we were able to kick off a render using Render Queue
    in C4D
    RENDER–>Add To Render Queue
    in render queue
    JOBS–> Start Rendering
    it should render using your output path and render settings.
    If anyone finds another solution, I’d love to learn it.
