Activity › Forums › VEGAS Pro › Render templates/ vegas studio platinum 9
  • Render templates/ vegas studio platinum 9
    Posted by Stewart Bourke on March 22, 2009 at 11:18 pm
    I am a recent convert to VMS Platinum, having finally got tired of the pinnacle stability issues. I was using pinnacle from v9 thrugh to 12, but have had so many issues with menus and transition corruption that I had to change. I have been using VMS for a short time now, and whilst I really like it, I seem to have hit an issue that make it impossible to continue using it.
    I have a 2 hour show that I need to fit onto a 4.7gb dvd. In studio, I used to reduce the bit rate down until I got the fiel size to where I wanted it. Normally, there has been no complaints about the quality. However, it seems this is not possible with VMS? I cannot believe that it i snot possible to adjust the bit rate when rendering, (the custom button is greyed out). I have checked the docs, forums etc and it does seem to me that VMS has been nobbled to disallow the custom button the VMS for some templates.
    Is there any way to reduce the bit rate on rendered mpg2 files? As I understand, I need to render the final output as mpg2 so I can use DVD Architect to add menus…
    Any pointers very much appreciated…
    Thank you
    Stewart Bourke replied 17 years, 6 months ago 2 Members · 2 Replies
  • John Rofrano
    March 24, 2009 at 3:14 am
    Try rendering to DV AVI instead. DVD Architect has a fit-to-disc option and it will calculate the correct bitrate and convert to MPEG-2 for you. Double check that DVD Architect Studio has this (I don’t have VMS I have the Pro version) but it should.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stewart Bourke
    March 24, 2009 at 7:03 pm
    It does – many thanks. I should have checked this, but I had assumed DVDA simply rendered what you gave it… Back to the tutorials… Appreciate the quick response.
