Activity Forums VEGAS Pro Render settings for a 4K video
  • Render settings for a 4K video
    Posted by Jono Grant on June 19, 2020 at 6:15 pm
    Hi there, I’ve filmed some 4K video using a Sony a6500
    I’ve edited some clips and added minimal brightness/contrast, nothing fancy.
    I’d like to render it at the best quality I can with Vegas. I’ll attach a screen shot of the settings right now, but I’m sure I can choose a better format to render to. Not an expert.
    Can anyone suggest a better format? M2t or something?
    Jono
    Jono Grant replied 6 years, 2 months ago 2 Members · 6 Replies
  • Jono Grant
    June 19, 2020 at 6:50 pm
    It may be helpful to show the specs of the original footage from the camera. Screenshot below. Thanks!
  • Jono Grant
    June 20, 2020 at 4:39 pm
    I guess everyone’s sick of this question! LOL
  • John Norton
    June 25, 2020 at 11:44 am
    Hi Jono, I’m sure the mp4 format is fine, all things being equal the higher the data rate then the higher the output quality. If your source is ~ 100 Mbps and you choose to render at about 1/4 of that data rate then your giving up quite a bit. It depends on what you’re use case is.
  • Jono Grant
    June 25, 2020 at 6:12 pm
    Thanks, ya, I don’t really get that stuff…:)
    I want to output it the best I can.
    Would you suggest changing the render settings under variable bit rate?
    What would be the best setting given the specs of the original video?
    Should I just enter:
    max: 100,000,000
    min: 50,000,000
    Thanks again!
    Jono
  • John Norton
    June 26, 2020 at 7:07 am
    Sorry for taking so long to get back, yes thats probably a good setting, but it all depends on what its destined for, private use, on say PC , head more towards the source data rate, for other uses just reduce, do an eyeball test in say any low light, high movement sections and make sure its ok.
  • Jono Grant
    June 26, 2020 at 6:36 pm
    Okay, thanks!
    Jono
