Activity Forums DaVinci Resolve Render settings
  • Render settings
    Posted by Bastiaan Houtkooper nsc on June 14, 2011 at 3:14 pm
    Did aynybody saw V8 render screens? Any changes?
    I am constantly struggling with putting my settings back. Not good after a long shooting day and easy to make mistakes. Shouldn’t be to difficult to save it in a ‘profile’ .
    Resolve system:
    MacPro 8 core 2010 – 16B memory
    9TB harddisk (1 system disk, 8TB in software raid 0 for data)
    Nvidea GTX285
    Nvidea GT120
    Blackmagic SDI Decklink
    RedRocketcard.
    Tangent Wave panel
    Transvideo 15″ Cinemontor Evolution
    Also running it on a MacBook Pro 17″ (5.2)
    160gb SSD and 750gb HD
    8gb mem
    Sascha Haber replied 15 years, 3 months ago 4 Members · 4 Replies
  • Margus Voll
    June 15, 2011 at 6:32 am
    I’m not sure what do you mean ?
    Margus
    https://iconstudios.eu
  • Bastiaan Houtkooper nsc
    June 15, 2011 at 6:37 am
    It’s simple, every time you press Apple-R for rendering, all settings or some settings jump back to defaults.
    When you open the program for the first time it jumps back to DPX renders.
    When it is the seoond render of the day, it might still keep the file format but things like rendersetting: “source” will be unchecked everytime again.
    A quick rerender always needs a check and re-check of the settings.
    IF you store the render settings in ‘profiles’ that can be set default, this would not happpen.
    Resolve system:
    Nvidea GTX285
    Nvidea GT120
    RedRocketcard.
    Tangent Wave panel
    8gb mem
  • Vladimir Kucherov
    June 15, 2011 at 7:33 pm
    I’ve definitely started renders only to hit myself on the head and have to redo. As of latest beta they introduced a preset pulldown but these seem canned presets for FCP so far, and I didn’t see a button to save your own into there.
    Now, you could use Batch Requests I think for this, sort of. If you make a batch request for a session, and then click on it later, its settings will be loaded into Render Properties. You can click, then render as normal.
  • Sascha Haber
    June 15, 2011 at 8:31 pm
    I think the render window, if executed in the same project should just show exactly the same settings.
    It might even ask to overwrite the files or offer to make a new version in a folder, but keep everything the same filenamewise.
    A slice of color…
    DaVinci 7.1.2 OSX 10.6.7
    MacPro 5.1 2x 2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
