Activity › Forums › Apple Final Cut Pro Legacy › Render Settings
  • Render Settings
    Posted by Sean Kapleton on October 4, 2010 at 3:23 pm
    Hello
    I know this will seem like a very basic question but somehow with all of my years of experience it is still somehow a topic of confusion between me and other editors.
    I have always been taught (video tutorials like lynda.com) to check all of the render settings but I notice a lot of editors only have a couple checked – I believe so they can just create and not focus on constantly having to render. I am more of an online editor so for me I need to do final renders of things so my settings are different of course.
    What I want to know is what can I leave unchecked because when i go into an offline editors room to help or deliver something i always end up checking everything and that annoys both me and the editor who has to change back his or her settings. How do I make FCP render completely and fully without having to check everything again when its time to deliver for tape, dvd, web, etc…
    I want to know the keyboard shortcut and settings that will render everything fully while still leaving most of those render settings unchecked for better work-flow for offline.
    cheers
    sean
    Sean Kapleton replied 15 years, 12 months ago 2 Members · 4 Replies
  • Rafael Amador
    October 4, 2010 at 3:46 pm
    Hi Sean,
    Truly important is to set everything to the higher setting on sporting.
    Before that, depends very much of your system, the job, your skills, self-confidence, etc.
    The point is that you work fast, comfortable, and that in the end the job is well done.
    [Sean Kapleton] “I want to know the keyboard shortcut and settings that will render everything fully while still leaving most of those render settings unchecked for better work-flow for offline”
    The setting that changes the rendering quality are accessible on the Preferences. No shortcuts that I know.
    Rafael
    http://www.nagavideo.com
  • Sean Kapleton
    October 4, 2010 at 3:53 pm
    not sure we are understanding each other here…
    This would be on a newer MacPro – all fast post-facility machines and I mean the settings tab at the top where it has Render and Render all where you can check different options – otherwise i know how to set my system preferences and such.
    maybe my question makes no sense? sorry if that is the case.
    sean
  • Rafael Amador
    October 4, 2010 at 4:18 pm
    Got it.
    Option-R.
    rafael
  • Sean Kapleton
    October 4, 2010 at 4:50 pm
    That’s what i figured but so do i have to check only certain render settings? I want to keep most things unchecked and speed up the offline process but want to still be able to do FULL renders without re-checking all of those settings…in the past when i have done this and hit option r i still see color bars notifying me that i need to still render something so I always end up having to check everything and then select all command R.
    thoughts?
    thank you
    sean
