Activity Forums Adobe After Effects Render settings
  • Render settings
    Posted by Spencer Tycksen on April 10, 2014 at 9:13 pm
    I have a comp that is taking forever to render. The comp is 3d, has particles, motion blur, camera wiggle, and is 5 minutes long – thus the long render. I had it rendering for 2 and a half days and then the external drive that I was using got bumped and it disconnected, so I lost the render. I’m about to restart, but I’m wondering if there is anything I can do to make it render faster.
    Does it make a difference whether I render to a local drive as opposed to an external? Here are my current memory settings: https://d.pr/i/8a1l
    Also, if I use Adobe Media Encoder to render rather than rendering right from After Effects, does that make any difference?
    Any tips would be greatly appreciated. Thanks.
    Mathew Fuller replied 12 years, 4 months ago 2 Members · 1 Reply
  • Mathew Fuller
    April 10, 2014 at 9:44 pm
    Commenting on how to make your render faster is too complicated a thing without getting deep into your project. I will say this.
    – Don’t render to an external drive, just a bad idea for many reasons, one of which you experienced.
    – I’d render an image sequence rather than a movie. That way if it crashes you can resume your render where it failed.
    – Try this script for BG rendering
    https://aescripts.com/bg-renderer/
    My Work:
    https://www.morecompletefx.com
