Activity › Forums › Adobe After Effects › Render Queue optimal settings for HD editing?
  • Render Queue optimal settings for HD editing?
    Posted by Nikos Mamalos on June 18, 2010 at 10:40 am
    I would appreciate any help on the following
    I need my final video to be in 1920*1080p for a final product either in Blu-ray or film
    transfer facility.
    I use AE and premiere CS4 or 5 on Macbook pro 2.6
  • With what sequence properties should I begin with in AE (a custom square pixel 1920*1080 25fps or an HDV 1440*1080)?
  • What are the optimal settings in AE Render Queue so that I could edit in real time in Premiere without initial rendering (without a red bar in timeline)
    Thanks a lot!
Nikos Mamalos replied 16 years, 3 months ago 34,291 Members · 2 Replies
    • Nikos Mamalos
      June 19, 2010 at 3:04 am
      First of all thank for your response. 25fps is because I am in a PAL area (Greece). Film transfer facilities I have contacted will equally accept both 24 and 25fps. Also not all of our cameras shoot 24fps. With the above said, do you have any suggestions for the other issues?
      Thanks again
      NM
    • Nikos Mamalos
      June 24, 2010 at 9:13 am
      Some questions are doomed to remain unanswered!
