Activity › Forums › Adobe After Effects › render questions
  • render questions
    Posted by Sergio Barrozo on May 20, 2008 at 4:50 pm
    What field order (upper field or lower field) I have to use when rendering a footage in After Effects that will be used in Adobe Premiere Pro v. 1.5?
    And what is the best CODEC available in AFX I have to use to get best results in Adobe Premiere?
    And in Adobe Premiere what is the setting (regarding to fields) I have to use?
    Any help will be appreciated.
    Erik Pontius replied 18 years, 4 months ago 2 Members · 1 Reply
  • Erik Pontius
    May 20, 2008 at 6:12 pm
    the field order is dependent on what you will be working in. DV is usually lower field first. HD is always upper field first.
    Lossless CODECs like Quicktime Animation are usually the best bet to get work from one application to another. Also image sequences, where each frame of video is output as a separate numbered image that can be re-compiled into video when imported.
    Mostly it will depended on what Premiere is capable of importing.
    Erik
