Activity › Forums › Apple Final Cut Pro Legacy › Render Questions
  • Render Questions
    Posted by Ron Moody on January 17, 2007 at 2:45 am
    Aloha from Maui,
    Im using an Imac Core2 Duo 2.33 with 3GIG of Ram and a 500GB Hard drive. While I understand that to get real-time output, I need an external drive, here’s my question.
    When I output a sequence to a movie file, the movie file has a couple of unrendered frames in it. I don’t get it. Prior to outputting the movie, I have used the command D keystroke to render all clips and transitions. Yet when FCP outputs a movie file, not all transitions are fully rendered. If I were trying to output to tape live, I could understand dropped frames, but I’m not.
    My background is Premiere and in that program, even if you don’t render the timeline, it renders it to the output file. I can’t think of a single reason that FCP should give me this result.
    Any ideas?
    Ron from Mai
    Ron Moody replied 19 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
