Activity › Forums › Adobe After Effects › Render queque, same composition and different layer visibility
  • Render queque, same composition and different layer visibility
    Posted by Manuel Montes romero on July 25, 2013 at 7:40 pm
    Hello:
    I have a question about adding the same composition to a render queque.
    I did a composition with different cameras and I need to render each camera separately to edit the final video in Premiere. I hace tried to add the composition with the 1st camera activated, then turn off that camera and turn on the next and add the composition again, but all the renders are done with the last camera that I activated.
    Is there any way to do that or I have to wait for all the cameras to render?
    Manuel Montes romero replied 13 years, 2 months ago 2 Members · 4 Replies
  • John Cuevas
    July 25, 2013 at 8:43 pm
    You need duplicates of the composition, 1 for each camera. So if you have 3 cameras, duplicate your comp 2 times(name them CAM1, CAM2, CAM3). Open each one and turn on the camera you want and each one to the render queue.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Manuel Montes romero
    July 25, 2013 at 8:45 pm
    That’s exactly what I was trying to avoid but it seems that I have no option.
    Thanks Johny
  • John Cuevas
    July 25, 2013 at 10:43 pm
    Understand. There’s a cool third party plugin for C4D that lets you take snap-shots of your comps(with different layers turned on/off) and you can then render the different versions.
    Sometimes duplicating comps in AE can be difficult if you have lots of precomps and maintaining hierarchy, if that’s the case for your project, you might want to check out this script: True Comp Duplicator Compatibility After Effects
    Thinkck.com
    July 25, 2013 at 11:08 pm
    I’ll check that script because (yes) I have a lot of precomps.
    Thanks again!
