Activity Forums VEGAS Pro Render Quality
  • Render Quality
    Posted by Woodman on November 29, 2005 at 8:23 pm
    How do I get the best quality video for my DVDA project? I noted when rendering, you can make changes under the Video tab. Space/size is not an issue as I am working with a 20 min clip.
    Using Vegas 6.0c and DVDA. Thanks
    Edward Troxel replied 20 years, 9 months ago 3 Members · 4 Replies
  • Edward Troxel
    November 29, 2005 at 10:04 pm
    The two main options are:
    1) Render from Vegas to MPEG2 and AC3
    2) Render from Vegas as DV-AVI and let DVDA convert to MPEG2 and AC3
    Either way will work fine but you have more control over your settings if you choose option #1.
    Edward Troxel
    JETDV Scripts
  • Woodman
    November 30, 2005 at 2:59 am
    When Rendering to MPEG-2 DVDA video stream, what do the different options under Custom settings mean. In the Video tab, there are options such as Video quality, Varible/constant bit rate, I frames, B frames. How do these effect the final quality and what should they be set to inorder to get the best quality. Thanks
  • Gary Kleiner
    November 30, 2005 at 6:53 am
    For your short video, set Video Quality to High.
    Constant bit rate at 8,000,000.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Edward Troxel
    November 30, 2005 at 3:10 pm
    There’s some info in Vol 1 #7 of my newsletters. Plus, take a look here:
    https://www.sonymediasoftware.com/download/step2.asp?DID=391
    Edward Troxel
    JETDV Scripts
