Activity Forums Apple Final Cut Pro Legacy Render Problems (PSD file)
  • Render Problems (PSD file)
    Posted by Rory Keenan on June 21, 2011 at 1:15 am
    My Graphics look good until I render them.
    Is there something I’m missing?
    I Imported a Photoshop file with an alpha channel.
    I need to lay this on a brown background.
    I have 2 layers of video:
    Layer 1- The logo (psd file)
    Layer 2- A color matte created in FCP
    The graphic look fine when I assemble it in a sequence
    However when I render it there is a weird pixelated halo around the graphic.
    It look terrible
    Any Solutions?
    James Vincent replied 15 years, 2 months ago 3 Members · 2 Replies
  • Michael Gissing
    June 21, 2011 at 5:48 am
    My guess (with such little important info supplied) is you are using a sequence codec that is highly compressed like DV.
    If so then choose a sequence codec that is kind on graphics like Uncompressed 10 bit or ProRes422. Change your easy setup, make a new sequence and copy paste your sequence into the new timeline. Re-render with render set to best
  • James Vincent
    June 21, 2011 at 8:02 pm
    do a test export (apple-E) and see if the psd still looks bad, it could be that your psd needs a full render (no grayish-green or green bar)
    -james
