Activity Forums Maxon Cinema 4D render problems
  • render problems
    Posted by Yan Fresh on February 28, 2008 at 10:18 pm
    Hi!
    Big trouble! When i render my scene with the render active button, the scene is perfect. When i render it (same frame) with the picture viewer button, it’s weird. The object in the scene have change position, or a leg who’s supposed to be bend is now straight…Any suggestions?
    Adam Trachtenberg replied 18 years, 6 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    March 1, 2008 at 6:47 am
    Sounds like you have some keyframes that are being calculated when you render to picture viewer but not in the editor — perhaps because you moved stuff around without keying. Hit the play button and see if things don’t match up.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
