Render problem, VEGAS 13 – InternetHD 1080p
Posted by John Skogly on June 8, 2017 at 10:02 amHi,
I render my videos in InternetHD 1080p, and I have some problems regarding the output material. I render pictures with music attached, and I only add the sharpening tool to the image. When I render, the video that comes out has moving pixels every 5-10 seconds or so. The material is normal, and the pixels change after 10 seconds, then changes back, and this happens throughout the video. The change is really subtle, but it is easy to see if you focus on it, and looks unprofessional.
How do I fix it? I use the standard 1080p settings for InternetHD in Vegas 13
John Skogly replied 9 years, 2 months ago 4 Members · 18 Replies -
Francois Pénzes
June 10, 2017 at 11:04 amHi John
What are the specs for your original material ? Please run MediaInfo and post. https://mediaarea.net/en/MediaInfo
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1\’\’When the cutting stops, the editing begins…\’\’
John Skogly
June 11, 2017 at 5:11 amhttps://gyazo.com/e2481dc6ee22a0ea5ef0c6768531c20b?token=cd5d4d5ff25de3626880a067e765500d
https://gyazo.com/487b8a09420376941f2cb18037d97156Two examples. I can show you the output on YT as well. It looks pretty bad.
https://www.youtube.com/watch?v=rl6RY4PCnEs
Even worse on this one.
https://www.youtube.com/watch?v=xPZxD73pmmk
My channel is semi big, but I do not know what I am doing wrong. I am a novice when it comes to Vegas, so any help would be greatly appreciated.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
James Ollick
June 12, 2017 at 3:02 pmJust check that when you added the sharpening you did not accidentally added a key-frame. That’s all I can think of.
James Ollick
Francois Pénzes
June 13, 2017 at 2:42 amHi John
So, if I read this right, the specs that you sent me are from the files that you uploaded to Youtube ?
What was (were) the effect(s) that you use on top of your background ? (Screen shot of your timeline would be nice)
When you say ”I use the standard 1080p settings for InternetHD in Vegas 13”, are you referring to MainConcept AVC/AAC ?
Have you tried rendering with Sony AVC/MVC Internet 1920X1080-30p also ?
Do you get the same effect with other types of render ? (.AVI, .MPG2, ETC…)
Cheers !
John Skogly
June 13, 2017 at 9:08 amhttps://gyazo.com/e056c8590285d347eea452f757295ea0
Example from my newest video. Fade effects and 0.5 sharpening on pictures (might be too much), and 0.6 sharpening on text. That is basically it. Correct, specs sent are from the two YT videos.
Yeah, InternetHD is referring to MainConcept, and I have also tried Sony AVC. I have not tried anything else, though. I cannot show the old .veg file as I do not save my project files. However, it happens on my new posts as well, although my newest videos are more subtle.
Should I try to render it in another format?
Francois Pénzes
June 13, 2017 at 10:43 pmHi John
I am seeing some artifacting in your blacks. (pixel blocks) For some reason the file may have been too compressed at some point.
When you are in Customize Template / Projects / Video rendering quality, Did you select Use Project Settings or Best ?
In File / Properties… / Video, can you do a screen grab of your settings ?
Cheers !
John Skogly
June 14, 2017 at 11:12 am[Francois Pénzes] “In File / Properties… / Video, can you do a screen grab of your settings ?”
https://gyazo.com/bdf60f4b92d194ff77046038eebe2532
Project properties for my uploads
[Francois Pénzes] “When you are in Customize Template / Projects / Video rendering quality, Did you select Use Project Settings or Best ?
“I use best for all my uploads.
Thanks for helping out!
Nigel O’neill
June 14, 2017 at 11:50 am[John Skogly] “The material is normal, and the pixels change after 10 seconds, then changes back, and this happens throughout the video. The change is really subtle, but it is easy to see if you focus on it, and looks unprofessional”
Right click the image on the timeline and tick ?
My system specs: Intel i7 7700k 4.20 GHz, GTX570, 16GB RAM, Gigabye Z170 HD3, Vegas Pro 12 (x64), Windows 10 x64 Pro, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
