Render problem, VEGAS 13 – InternetHD 1080p
John Skogly replied 9 years, 2 months ago 4 Members · 18 Replies
John Skogly
June 14, 2017 at 2:16 pm[Nigel O'Neill] “Right click the image on the timeline and tick ?”
What Should I tick?
Francois Pénzes
June 15, 2017 at 2:19 amHi John
Try these settings in File / Properties… / Project Properties:
11449_projectproperties.jpg.zip
Setting Good in Full-resolution rendering quality uses bilinear scaling without integration, while Best uses bicubic scaling with integration. If you’re using high-resolution stills (or video) that will be scaled down to the final output size, choosing Best can prevent artifacts.
On a final note, use the 8 bit setting for when you are editing and the 32-bit floating point (video levels) when you do your final render so not to bog down your rig.
Let me know how it works out.
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
Cameras: Canon XF305 + Canon XH-A1\’\’When the cutting stops, the editing begins…\’\’
John Skogly
June 15, 2017 at 8:53 amHi,
https://www.dropbox.com/sh/yfp5h45k6q08ew9/AACFssjBgwhWk4RNJ80z3qwSa?dl=0
Various files are added here. I have tried to solve the problem on different sites, but to no avail. See if some of these can help you. The rendered file with your settings are included, in addition to the .veg file. Your render definitely seemed to help, and the video looks better in comparison when uploaded to YouTube. It seems to mainly be a problem with Youtube, though, as the videos look much better when using the local file. However, I believe the problem is still there. In my original AVC file I can spot it playing the local file, which leads me to the conclusion that it is prevalent in all my renders. Then, when YouTube recompresses the file, it is more noticeable because of the quality drop. Hence why the issue is easier to spot in lower quality, for instance 720p instead of 1080p.
It is just speculation, though. Again, thanks for helping!
Nigel O’neill
June 15, 2017 at 1:45 pm[John Skogly] “Right click the image on the timeline and tick “
Reduce interlace flicker
My system specs: Intel i7 7700k 4.20 GHz, GTX570, 16GB RAM, Gigabye Z170 HD3, Vegas Pro 12 (x64), Windows 10 x64 Pro, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
John Skogly
June 15, 2017 at 5:27 pmhttps://www.youtube.com/watch?v=lnZakwbl2Vs
With your settings. It seems like the problem is mostly on YouTube’s part, and it shows up easier in certain photos, because of the coloring. Using logos with little/no shadow around them also seem to make it better.
I cannot really see it in 1080p, but it is still slightly visible on the rock part of the image in 720p. Thanks for all the help! I do not really know if there is anything else to do. It does not bother me on this particular upload, but I know that it reacts differently with other photos.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Francois Pénzes
June 16, 2017 at 3:31 amHi john
Here’s a link that will explain what’s happening:
https://en.wikipedia.org/wiki/Compression_artifact
You can minimize the artifacting by rendering progressive and using a .PNG file instead of .JPEG
Also, go to Custom Settings and select Use deblocking filter, that will reduce the amount of unwanted artifacts.
Cheers !
P.S.: Is that your music ? (it’s part of my playlist now…)
John Skogly
June 16, 2017 at 11:48 amHi,
I am going to try those settings next time I render!
[Francois Pénzes] “P.S.: Is that your music ? (it’s part of my playlist now…)”
Glad you liked it! I do not make the music, I am just a promoter. I ask for permission to use songs I like, and post them if granted.
