Activity Forums DaVinci Resolve Render problem
  • Render problem
    Posted by Dan Davis on November 2, 2011 at 6:16 pm
    I know this must be a simple one, but I’m missing it.
    In config I’m pretty sure all my setting are correct (working pal 25frames Prores)
    When I go to render the only options I’m getting in frame rate are 23.98 and 24.
    I need to render at 25.
    Any advice would be great.
    Danny.
    Dimitrios Papagiannis replied 14 years, 10 months ago 4 Members · 4 Replies
  • Dwaine Maggart
    November 2, 2011 at 8:58 pm
    Your render frame rate options are determined based on the setting of the “Timecode Conform Options” “Timecode calculated as:” frame rate, on the Config page Project tab. You MUST set this setting correctly before starting a project, as it can not be changed after the fact. Based on what you see, it sounds like this setting is at 24, and needs to be 25.
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Jake Blackstone
    November 3, 2011 at 3:24 am
    Which, unfortunately, also means, that you’re pretty much screwed. There is no way, that I know of, to change the setting of the “Timecode Conform Options” “Timecode calculated as:” frame rate after conform. You can only change it AFTER you delete all your material in the library. If you find a solution, please let me know…
  • Dan Davis
    November 3, 2011 at 12:05 pm
    Thank you very much for getting back.
    I’ll work my way through it!
    Danny.
  • Dimitrios Papagiannis
    November 5, 2011 at 5:37 am
    Just a question Dwaine. Does it matter if I put 59.94 or 60 in that field? Or which one should I put?
    thanks
    Dimitrios
