Activity Forums Apple Final Cut Pro Legacy Render Problem
  • Posted by Todd Drezner on September 6, 2006 at 6:00 pm
    I opened a project that I hadn’t worked on for about a month and got a message that all my render files were offline. The timeline shows them as red or green, but when I try to render nothing happens. All the options in the render menu are checked.
    When I play the timeline, I do not get a media offline screen when I get to the unrendered parts. Instead, I am seeing a green screen. If I change the RT options to Unlimited RT, the render files play back as pre-render quality, but the timeline still will not render. Finally, when I export a quicktime, the rendered files in the resulting quicktime look fine.
    The timeline is a DV-NTSC timeline in FCP 5.0.4 on a 2.5GHz G5 with 1 GB RAM. The drive is a 1 TB Lacie firewire. Any suggestions would be appreciated. Thanks,
    Todd
    Todd Drezner replied 20 years ago 3 Members · 3 Replies
  • David Roth weiss
    September 6, 2006 at 7:16 pm
    Todd,
    Hate to tell ya, but I had similar rendering issues a few weeks back and I tried everything to fix it, but to no avail. Eventually I reinstalled all software from the from the ground up and that fixed the problem.
    DRW
  • Teerav
    September 6, 2006 at 7:19 pm
    have you tried flushing all your render files. click on “Tools” and then click on “Render Manager”, put a check next to every file in the list and click ok. now, before hitting render. go into your scratch disk from the finder and delete the “Render Files” & “Audio Render Files” Folders. ive had a similar problem with render files and this seems to always fix it for me. good luck
  • Todd Drezner
    September 6, 2006 at 8:40 pm
    Deleting the render files worked. Thanks for the help,
    Todd
