Activity Forums Maxon Cinema 4D Render Particular layers ONLY, while leaving the effects of others on those layers.
  • Render Particular layers ONLY, while leaving the effects of others on those layers.
    Posted by David Biederbeck on September 14, 2010 at 6:12 pm
    Is it possible to render out particular layers (text in this case), keeping the effects that all other aspects have on it (lighting/sky/softboxes etc.) and make all other areas of the still render on the alpha channel?
    Essentially I only want to use the text (with the scenes effects) and bring it into photoshop.
    Thanks in advance!
    David Biederbeck replied 16 years ago 2 Members · 2 Replies
  • Tyler Joynt
    September 14, 2010 at 6:22 pm
    I believe what you want is just to put a Compositing Tag on everything that you dont want and uncheck “Seen By Camera”
  • David Biederbeck
    September 14, 2010 at 6:44 pm
    Thank you so much!
    That was perfect.
