Activity › Forums › Maxon Cinema 4D › Render output has more polygons than viewport render
  • Render output has more polygons than viewport render
    Posted by Alex Berger on November 15, 2018 at 5:49 pm
    Hello,
    I’m pretty new to Cinema 4D. I made a few low poly clouds for work and need to render them out as PNGs (for now, but I will need to be able to render as a 3D object later for use in AE). Everything looks right in the viewport, but when I render out as PNG, the polygon count increases. This also happens if I make the objects editable.
    What am I doing wrong? Thanks in advance.
    Mac OS 10.13.6
    Cinema 4D R17
    C4D file: https://www.dropbox.com/s/qjuewv62y04gajh/clouds.c4d?dl=0
    Alex Berger replied 7 years, 10 months ago 2 Members · 2 Replies
  • Brian Jones
    November 15, 2018 at 7:52 pm
    thanks for providing the file it would have been just a bunch of guesses without it. You are using Metaballs to create the clouds, each metaball has an Editor Subdivision and Render Subdivision setting. You want the Render setting to be the same as your Editor setting (44.264).
    Usually the metaball is used for smooth blobs and the editor setting is a lot bigger for viewport speed with the render setting smaller for smoothness of surface.
  • Alex Berger
    November 15, 2018 at 7:53 pm
    Thank you for your reply! I found your solution worked perfectly.
