Activity › Forums › Adobe Premiere Pro › Render only the red portion of the renderline, it it possible?
  • Render only the red portion of the renderline, it it possible?
    Posted by Joel Arvidsson on December 14, 2012 at 10:33 am
    Can you choose to only render the parts that have the red renderline? The yellow is realtime anyway and its just waste of time it will render to. I dont like to move the workarea bar from place to place.
    Seams to not render the yellow now. Must be the cuda? before I did render the yellow.
    joelarvidsson@gmail.com
    Jeff Pulera replied 13 years, 9 months ago 3 Members · 2 Replies
  • Ann Bens
    December 14, 2012 at 12:53 pm
    If you hit Enter it just renders the red lines (Effects in Work Area)
    If you hit Render Entire Work Area under Sequence it will render everything including the yellow lines.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Jeff Pulera
    December 14, 2012 at 5:10 pm
    Here is Adobe info on the colored bars – https://blogs.adobe.com/premierepro/2011/02/red-yellow-and-green-render-bars.html
    Note that it is not recommended to use the render previews for your final output, so unless playback quality is intolerable, I do not bother rendering in the timeline and just let that happen during final export from AME.
    Jeff Pulera
    Safe Harbor Computers
