Activity Forums Apple Final Cut Pro Legacy render limit?
  • Posted by Michael Garske on April 30, 2011 at 12:30 am
    Whenever I’m rendering new items in a timeline previously rendered items become unrendered occasionally.
    Is there a way of controlling the amount of allowed rendered video in a timeline to fix this? I assume it’s just some kind of preference but I couldn’t find any setting for that. Thanks again!
    Scott Rucci replied 15 years, 3 months ago 4 Members · 4 Replies
  • Rafael Amador
    April 30, 2011 at 7:24 am
    Hi Michael,
    There is no limit for rendering a sequence.
    That buggy behave was very typical in some FC.5 and FC.6 versions but seems to be fixed in FC.7.
    rafael
    Rafael
    http://www.nagavideo.com
  • Scott Rucci
    April 30, 2011 at 6:30 pm
    Hmm. I’m working in 7 & it happens constantly unfortunately. Maybe I’ll have better luck with X when it comes out. Have you ever experienced this glitch or know of any work arounds?
    Scott Rucci
    Rucci Productions
    ruccipro.com
  • Ben Holmes
    May 1, 2011 at 3:33 pm
    There was a bug in 7.0 that caused this in duplicated timelines – it was solved in 7.0.1 as far as I know, so ensure you have the latest version via software update.
    Otherwise, if it happens a lot you have a bad install, or your FCP preferences are corrupted, or both. Use FCP rescue or FCP maintenance pack, and reinstall the whole suite from scratch if possible – this is one reason why an edit system should not have a lot of other software on it.
    I can assure you this is NOT typical behavior for FCP suites.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Scott Rucci
    May 1, 2011 at 6:42 pm
    Just FYI this post was also made by Mike, we work together, I just think he accidentally was signed on as me. : )
    Scott Rucci
    Rucci Productions
    ruccipro.com
