Activity › Forums › Adobe After Effects › Render issues, says disk is full?
  • Render issues, says disk is full?
    Posted by Mike Johnson on March 19, 2017 at 7:17 am
    I tried to render a small project in Adobe After Effects, and after about 7 minutes I heard a “baaa” sound(or something close to it) with a notification that the render failed and “disk full” and that the “file may be corrupt.” The flash drive I was rendering it to certainly had enough space, and when I tried rendering it again it failed at around the same time, and interestingly what was left of the semi-rendered file was the same size as the previous one. 4,179,644 KB to be exact. Why is this happening? What can I do to fix it? Help would be much appreciated.
    Mike Johnson replied 9 years, 6 months ago 2 Members · 2 Replies
  • Gary Milligan
    March 19, 2017 at 6:05 pm
    In addition to what Dave says, it could also be that you’ve reached the file size limit (4GB) of the FAT32 formatted drive.
  • Mike Johnson
    March 19, 2017 at 11:36 pm
    Well, I guess my flash drive didn’t have enough space, even though I’m sure it did. I tried rendering it to my hard drive and it worked! So I guess it was just an error on my part.
