Activity › Forums › Adobe After Effects › render issue: AE locks up on a specific frame
Posted by Brian Johnson on October 29, 2007 at 1:13 amI’m working on one of my first AE projects, and no matter how I render (RAM preview or all the way) AE locks up and says “not responding” on the exact same frame every time…2:07. Anybody know if I’m doing something wrong? Thanks for any help!
Aharon Rabinowitz replied 18 years, 11 months ago 3 Members · 4 Replies -
Steve Roberts
October 29, 2007 at 1:49 amYou need to find out what’s special about that frame, or that number of frames rendered.
Hide layers, especially those with effects until it works.
Disable effects (the “fx” switch) until it works.
Disable audio layers until it works.
Check your OS utility that tells you how much RAM you’re using.
Disable Open GL... then get back to us. 🙂
Brian Johnson
October 29, 2007 at 4:56 amWhen I reduce to 1/4 and do a RAM preview, it works fine. But if I try to at full quality, or try to render at full quality, it locks up AE. I’ve only got 1 GB of ram and I’m doing some pretty complex stuff with the help of Mr. Kramer and his Riot Gear product. Do I need to upgrade my RAM, maybe?
Steve Roberts
October 29, 2007 at 5:29 amYow! 1 GB is nothing these days — you need at least 2-4, or 1 per core. If you’re on Windows, open Task Manager, and if you’re on Mac, open Activity Monitor to check your RAM usage.
Now if you want to render while you still have only 1GB of RAM, try the secret prefs. Access Preferences>General, and hold down the shift key until you see the big Prefs dialog. Hold down the shift key longer than you think, if necessary. Click general to see the drop-down, and you’ll see “secret” at the bottom of the list. Try purging every 5 frames during Make Movie there.
Aharon Rabinowitz
October 29, 2007 at 3:23 pmYou should definitely upgrade your RAM, no question, but you still might be able to do this.
Watch this video about the Secret menu and dumping your ram cache during render:
https://library.creativecow.net/articles/rabinowitz_aharon/workflow_2.php
Aharon Rabinowitz
Email: arabinowitz (AT) yahoo (DOT) com
All Bets Are Off Productions, Inc.
Creative Cow After Effect Podcast
Internet Killed the Video Star: A Guide to Creating Video for the Web
