Activity Forums Adobe Premiere Pro render issue
  • render issue
    Posted by Paul Miil on July 20, 2009 at 12:38 am
    XP x64 server (2003) sp2
    Intel core 2 quad (4 cpus) Q6600 @ 2.4 GHz
    4 GB of RAM
    500 GB HD with 180 GB free
    NVIDIA card with 500M.. I think.. can’t quite remember.
    Premier Pro CS3
    I’m rendering a
    NTSC 720×480
    Microsoft DV AVI
    Embedding options “project”
    DV NTSC
    Millions of Colours
    29.97 fps
    aspect D1/DV ntsc widescreen 16:9 (1.2)
    data rate: recompress – maintain data rate
    Bit depth: project setting
    Audio
    uncompressed
    48kHz
    16 bit
    stereo
    interleave: 1 sec
    The project is 58 minutes long, but the header is corrupt when I render the AVI.
    I can render a short version fine,
    I can render the entire video (no audio) fine,
    I can render the entire audio (no video) fine,
    I can not render both the audio and video together for the entire length without getting a corrupt header.
    I check the rendered AVI with Gspot codec info appliance and it tells me that it is an invalid AVI due to corruption in the Header and it goes on to say that it is a serious problem.. lol.
    The details are “while processing chunk /RIFF:AVI, found bad length value 2 147 035 844 at file offset 0x00001af4.
    Am I trying to render a project that is too long? Should I break it up to say 10 minute segments or something?
    I have no probs rendering 5 minute vids.
    This 58 minute project does however have a lot of MP3s (with various rates), some WAV, and quite a lot of stills and AVI’s, 11 audio and video tracks (all though only used for about 10 seconds) the rest is around 2 video and 2 audio tracks.
    Any help or suggestions would be appreciated… as I’ve been working on this project for about a year and would hate to not be able to render it.
    Paul Bibby replied 17 years, 2 months ago 2 Members · 5 Replies
  • Paul Bibby
    July 20, 2009 at 1:55 pm
    Why may I ask are you rendering to AVI
  • Paul Miil
    July 20, 2009 at 2:22 pm
    The reason why I am rendering to AVI is because I intend to burn the project to DVD.
    I don’t know of a way to render from premiere direct to DVD VOB so I am rendering it to AVI which then can be converted to VOB format.
    I am only able to render a max of 5 minutes worth without drawing a corrupt header. I’ve tried 30 min, 20, 15, 10 and all render with corrupt header.. citing bad length while processing chunk /RIFF:AVI
    Do you have a solution to my problem?
    Or know of a way to render/export a project direct to DVD format?
    Today’s mighty oaks were yesterday’s nuts that held their ground.
  • Paul Bibby
    July 20, 2009 at 2:52 pm
    Try rendering to mpeg2 thith the adobe media encoder in the export settings in Premier Pro I use CS3 but CS2 has it to I don’t know if the previous versions have It, The setting I would suggest
    Format: mpeg2-dvd
    Quality: 5
    Bitrate Encoding: VBR, 2 pass
    in the multiplexer select DVD that will put the audio and video in one file.
    VOB files are basically mpeg2’s
    Hope this helps
  • Paul Miil
    July 21, 2009 at 3:37 pm
    Thanks, such a simple solution.
    MPEG2 rendered and played back fine.
    Although I couldn’t render progressive, only interlace.
    I’m assuming that’s because my camera shot on 30I.
    I remember something about de-interlace.. but I’m not too worried about it, though I would prefer progressive.
    And the rendered Mpeg2 is only 2.5 Gig instead of the AVI’s 12.5 Gig, not that size really matters.
    This leaves me wondering why I was always using AVI.
    Thanks again, your time saved me a lot of time.
  • Paul Bibby
    July 22, 2009 at 5:58 am
    There is a setting to export progressive in the field order setting see image
    Hope this helps.
