Activity › Forums › Adobe After Effects › Render Friendly Alternative to Echo
  • Render Friendly Alternative to Echo
    Posted by Eric Arsnow on February 25, 2021 at 12:59 am
    Hello, I was trying to do a huge time collapse / frame trail on an animation using echo. It has always worked fine but I was wondering if there were any recommendations for something a little more render friendly?
    Eric Arsnow replied 5 years, 7 months ago 2 Members · 2 Replies
  • Filip Vandueren
    February 26, 2021 at 3:44 pm
    Cc blend time, which you can access via the animation presets available here:
    http://www.cycorefx.com/dloads_ccfxhd.php
    It’s an officially unsupported but lightning fast way to just copy the previous render buffer back over the frame. Which means it doesn’t do what you expect it to do if you quickly scrub around the timeline. So clear the cache often and just do straight ram previews from start to finish of the layer to get the actual effect.
  • Eric Arsnow
    February 26, 2021 at 3:48 pm
    Thanks much for the reco! I’ll take a look!
