Activity Forums VEGAS Pro Render Freeze with slow motion
  • Render Freeze with slow motion
    Posted by Jim Kaye on September 2, 2008 at 5:06 pm
    Trying to render a 30 minute project, I got freezes/crashes at several clips which I streched for slow motion. I rendered these clips individually to a new clip and reinserted them. I was then able to render past them, and eventually got the entire project done. Has anyone seen this problem? Is there an easier work around as it takes a long time of renderint to find the problem points.
    Jim
    Steve Nye replied 18 years ago 2 Members · 3 Replies
  • Steve Nye
    September 2, 2008 at 5:25 pm
    I have reported a similar issue – 4 topics below this one entitled ‘Rendering issues’ one of which is freezing when rendering speeded up clips. I am going to try your suggestion and see if that solves the other issue? Steve
  • Jim Kaye
    September 2, 2008 at 5:29 pm
    Interesting. I did see a similar post by Suzy Shepherd which looks like the same issue. Mine occurs rendering to .mpg for burning DVD’s. Sounds like a bug in Vegas 8.0.
  • Steve Nye
    September 3, 2008 at 5:43 am
    It looks like I have two issues. The first is on speeding up clips which seems to be a firm bug in Vegas with a workaround to render a smaller section and then import into the main project – problem resolved.
    The second issue I have appears to be Vegas not correctly importing M2ts files.
    Basically I can render an M2ts file using the same parameters and when I then try to import into Vegas it only brings in one audio stream. I can render a small section of the project and it then imports fine. If I use the PS3 I can playback all files fine no problems.
    I also tried a trailer that I had downloaded and Vegas just gets an error and closes. If any one has some time I would be interested to see if they also have that issue. The trailer was loacated here
    https://www.demo-world.eu/trailers/redirect-high-definition.php?file=hd_other_blu_ray_lasers.rar
    I am sure that I have been able to import some of the files I am now having issues with before – but can’t be certain. I have reloaded Vegas and it does not make a difference I am on the current version 8.0b. any suggestions?
    Steve
