Activity Forums Adobe After Effects Render Farm
  • Render Farm
    Posted by Luis Morales on December 21, 2007 at 2:29 pm
    Hello everyone
    I just finished setting up my new render farm, which consists of 8 quad PCs wired over a gigabit ethernet. Ive tried rendering in both watch folder mode and old-fashioned network rendering (opening the project on each machine and rendering w/skip existing files checked)
    and what i see is that only 2 or 3 machines are actually rendering frames, while the others are just skipping files…
    I suspect a network bottleneck, but maybe there’s another reason…
    Any ideas?
    Cheers and happy holidays to all of you,
    L
    Tristan Nieto replied 17 years ago 4 Members · 3 Replies
  • John Bloom
    March 31, 2008 at 8:45 pm
    I’m having the same issue. Has anyone ever figured this problem out?
    -John
  • Thai Tran
    September 11, 2008 at 7:28 pm
    I have the same issue with a bunch of 8-core MacPro’s in our studio. This seems to happen when I am trying to do multiprocessing on each machine. To fix the skip file hang-up, start the same render again using only one core (either by force quitting the BG processes or just starting the render again without MP turned on). The machines will skip files correctly instead of taking eternity to skip one file.
    This is just obscene. You have these $3k machines working in tandem and they can only render using one of their eight cores. WTF?!
    Each of our boxes has anywhere from 6GB’s to 8GB’s of RAM. I’ve adjusted the Maximum RAM Cache Size to use only 1GB so there should be enough memory available for each BG process to work with. But there are always problems on render output. For instance:
    MP RENDERING ON ONE BOX: The render will go using 8 cores for a few frames then quit the BG processes and go back to one core rendering. Seems to be random. Furthermore, at other times, it will just take longer (relative to single core rendering) to render frames. However, RAM preview doesn’t seem to run into this issue, it works great actually (other than the slight lag when you go into and out of a RAM preview).
    MP RENDERING ON MULTIPLE BOXES: When the boxes come upon a pre-existing frame spit out by another box they will take forever to skip that frame. I’ve tried splitting up the comp into sections for each machine, but then the boxes will run into either the BG-process-quitting problem or the slow-as-molasses-processing-of-frames problem.
    I’m open to any and all suggestions because right now I’ve got four 8-core machines and it’s a shame that it takes all of them running to do the work that one machine could potentially do by itself. For shame, Adobe. For shame….
    “If at first you don’t succeed, destroy all evidence that you tried in the first place.”
  • Tristan Nieto
    September 3, 2009 at 11:11 am
    Sorry to exhume an old thread, but I’m now having this issue too.
    Was it ever resolved?
    Tristan Nieto
    Visual Effects & Motion Graphics
    tristannieto.blogspot.com
