Activity Forums Adobe After Effects render failed
  • render failed
    Posted by Betty Boop2 on December 19, 2005 at 4:56 pm
    Perhaps someone could guide me on this. I get a lot of “render failed” on AE projects, so I offen, as a example have to render small sections, say 2 secs each to get a 16 sec piece finished.
    Have…
    Dell-670
    Windows XP Pro SP2
    AE 6.5
    ton o ram
    Duel xeom cpu 3.40ghz
    Nivieia Quadro FX 3400 card
    Any advise out there?
    Elie Romano replied 16 years, 8 months ago 4 Members · 4 Replies
  • Steve Roberts
    December 19, 2005 at 6:15 pm
    Search the COW for “secret prefs”, then get back to us.
    Steve
  • Betty Boop2
    December 20, 2005 at 4:33 pm
    Thanks Steve.
    I followed your instructions and the render problem went away.
  • Peter Doris
    May 12, 2009 at 1:11 am
    Brilliant,
    Thank you so much worked for me too
    Best
    P
  • Elie Romano
    January 8, 2010 at 4:41 pm
    I’ve been looking for a solution myself on this problem and wasn’t able to find a fix that worked for me. I told myself, what was changed in after effects ever since I had this problem. I then noticed that my comp. was set as 32 bit. I decided to give it a try with 16 bit and I haven’t had a render issue since.
    I hope this helps you out as it did for me
