Activity Forums Adobe After Effects render error
  • render error
    Posted by Yair Neumann on June 5, 2009 at 5:40 pm
    Hello,
    I’m sending this mail after I’ve searched the entire web for an answer and sadly have come up with nothing…
    I’m trying to render a comp in after effects, the comp is a sequence of jpeg at a size 1800×1200. I’ve added timewarp to get an effect just like frameblending eventually giving me something between stills and video.
    Each time I render Im getting an error message saying:
    “After Effects: not enough memory to create Kronos image.(16875k,15680k available)
    “after Effects error: Timewarp out of memory. (4)
    ( 25::60 )”
    I understand that there is a problem of insufficient memory, Is there anything I Can change in me preferences settings in order to finish this render?
    Amongst the things I’ve tried is pressing the shift key when I enter the preferences dialogue and changed the “secret” settings so it will purge every 5 frames.
    Thank you very much for taking the time to help me.
    Jason Heinze replied 17 years, 2 months ago 2 Members · 3 Replies
  • Jason Heinze
    June 5, 2009 at 7:18 pm
    Ironically I just had the same error message. I was able to fix it by increasing my maximum memory usage to 160% and maximum RAM usage to 60% then enabled disk cache up to 12000MB. It worked fine.
    cheers
  • Yair Neumann
    June 6, 2009 at 8:46 am
    I’m still getting the same error after I changed the settings…
  • Jason Heinze
    June 6, 2009 at 8:00 pm
    Does your comp allow you to render with Open GL? The addition of your video card depending on its power could help push you though. If not, try increasing your disk cache size more.
