Activity Forums Maxon Cinema 4D Render Cinema 4d – noise
  • Render Cinema 4d – noise
    Posted by Michael Woj on March 9, 2016 at 11:08 am
    Hello!
    I have some problem with render. I don’t know why everything is moving on the coach – I think that is some noise – but why? In preview render it was fine.
    https://vimeo.com/158312450
    What do you think?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Andy Sills replied 10 years, 5 months ago 3 Members · 2 Replies
  • Brian Jones
    March 9, 2016 at 3:14 pm
    you are animating while using GI… Check out CINEMA 4D/CINEMA 4D Prime/Render Menu/Edit Render Settings/Global Illumination/Tips and Tricks in the Help – it has a “GI and Animation” section near the bottom which has some good info.
  • Andy Sills
    March 9, 2016 at 3:54 pm
    It could also be a compression issue.
    Sometimes streaming websites will compress the video for easier viewing, but that will create noise.
