Activity › Forums › Apple Final Cut Pro Legacy › render chime and collect files
  • Shane Ross
    December 21, 2008 at 6:12 am
    COllect Files:
    https://digitalheaven.co.uk/loader/
    Render Chime…well, someone made something, but I can’t find it anymore.
    https://lfhd.blogspot.com/2007/07/render-alert-for-final-cut-pro.html
    Shane
  • Brandon Morris
    December 21, 2008 at 6:16 am
    oh by collect files i meant also at the end.
    it resaves all the used files for that project where u tell it.
    in AE it looks at the files ur projects uses and will reduce to only the used files.
    i  my mac.
  • Andy Mees
    December 21, 2008 at 11:25 am
    It was the wonderful Andreas Kiel’s Render Alert applescript:
    tell application “System Events”
    tell application process “Final Cut Pro”
    set windowList to get name of every window
    end tell
    end tell
    if windowList contains missing value then
    beep 5
    end if
    quit
    Copy and paste that into the Script Editor app in the /Applications/AppleScript folder and save it as an application
    Drop the app in your dock. Once you start a render, click on the render alert in the dock. Nothing will happen until the render finishes, at which stage your system alert sound should sound five times.
    You must have Universal access activated for this to work – which is in OS X’s System Preferences > Universal Access > tick the box “Enable access for assistive devices” at the bottom of the window.
    For extra credit you can change the “beep 5” bit to do something more flashy like send you an SMS via Skype or Email …
    tell application “Skype”
    activate
    end tell
    tell application process “Skype”
    set theTarget to “skype:” & internationalPhoneNumber & “?sms”
    open location theTarget
    keystroke theText
    delay 2
    keystroke tab using shift
    keystroke return
    end tell
    end tell
    or
    set the_number to “5555555555@message.alltel.com”
    set the_message to “Your Final Cut Pro Render is Complete”
    set the_subject to “FCP Notification”
    tell application “Mail”
    set new_message to (make new outgoing message at end of outgoing messages)
    tell new_message
    set visible to true
    make new to recipient at end of to recipients with properties {address:the_number}
    set subject to the_subject
    set content to the_message
    send
    end tell
    end tell
    none of this code is mine … its all scavenged from various quick searches of the internet for Andreas’ Render Alert helper app
    https://www.editorsguild.co.za/documents.html
    https://www.screeneditors.com/forums/showpost.php?p=5086&postcount=20
    https://community.avid.com/forums/t/45992.aspx
    https://www.sms411.net/2006/07/how-to-send-email-to-phone.html
  • Shane Ross
    December 21, 2008 at 4:28 pm
    [brandon morris] “it resaves all the used files for that project where u tell it.”
    That is called the MEDIA MANAGER.
    Shane
  • Arnie Schlissel
    December 21, 2008 at 7:05 pm
    [brandon morris] “oh by collect files i meant also at the end.
    Honestly, I do this while working on the project. As new media gets added, I try to keep it in as few places as possible, all very clearly labelled. Still should all go in one folder, lower 3rds and graphics in one folder, music in one folder, SFX in one folder, etc. All on the same RAID, all labelled with the project’s name so that everything can be found very quickly, and all can be backed up easily.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • David Holmes
    March 2, 2009 at 10:41 am
    I followed the directions. ..So why are the chimes coming in the middle of the render instead of at the end? A fluke?
