Activity Forums VEGAS Pro Render cancelled by user – nothing happens, any way to save my project?
  • Render cancelled by user – nothing happens, any way to save my project?
    Posted by Mark Romans on March 3, 2016 at 10:21 pm
    Hi all,
    I’ve made a mistake. I spent a few hours putting something together in Vegas 7 (I know, old) and never saved it. I started to render and then wanted to cancel out but when I did, it just says “Render cancelled by user” and the dialog box doesn’t go away. I’ve left it for a few hours now and no change. My pointer still has the little sand timer next to it.
    Will Vegas auto save my project so I can recover it if I end the program while it’s in this little “thinking” phase? Should I let it go over night and see if it ever cancels?
    Any responses will be much appreciated!
    John Rofrano replied 10 years, 6 months ago 2 Members · 5 Replies
  • John Rofrano
    March 3, 2016 at 11:58 pm
    [Mark Romans] “Will Vegas auto save my project so I can recover it if I end the program while it’s in this little “thinking” phase? Should I let it go over night and see if it ever cancels?”
    There should be an autosaved project with your project name and the extension .veg.bak but since you never saved it you might not have this file. If you did, it would be called Untitled.veg.bak. If you don’t see that file, you have nothing backed up.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Mark Romans
    March 4, 2016 at 12:11 am
    Thanks for the response JR! I’ve done a search for it and nothing came up. It would be Untitled as that is what it says on the project currently. Is this because I never saved anything? 🙁
    Do you think there’s any chance it’ll correct itself if I let it run long enough? Might it create a backup when I end the program. I’m grabbing at straws here. Thanks.
  • John Rofrano
    March 4, 2016 at 1:02 am
    You ave nothing to loose by waiting. I’m almost certain you will loose everything if you kill it… but it doesn’t sounds good. 🙁
    ~jr
  • Mark Romans
    March 4, 2016 at 7:36 pm
    Thanks again, John, but it actually did autosave. I got my project back….albeit with some other issues, which I’m solving now. I appreciate your help!
  • John Rofrano
    March 5, 2016 at 2:31 am
    You’re welcome. Glad it autosaved an unsaved project. That’s impressive.
    ~jr
