Activity Forums DaVinci Resolve Render cache
  • Render cache
    Posted by David Baud on November 11, 2013 at 5:34 pm
    I am working in Resolve 10 in a project with 2 timelines.
    When using render cache, if I switch to the other timeline, I loose all my render cache from the first timeline.
    Is there a way to make sure the render caches are saved so someone does not have to recalculate them all the time??
    David Baud
    Post & VFX
    KOSMOS PRODUCTIONS
    Denver – Paris
    http://www.kosmos-productions.com
    David Baud replied 12 years, 10 months ago 2 Members · 2 Replies
  • Sascha Haber
    November 11, 2013 at 8:07 pm
    no 😉
    Still not..
    Even if the request is as old as Resolve by now.
    But you could render the whole thing using the “professional workflow” ad then create a playback timeline with the outputs.
    We do this on systems that are to slow to work in RT from RED files or have no external GPUs.
    A slice of color…
    Resolve 10.0.0.073 , Smoke 2013 EXT
    Colorist / VFX / Aerial footage nerd
    https://vimeo.com/saschahaber
  • David Baud
    November 12, 2013 at 3:29 pm
    Thanks Sascha… yes it is too bad that Render Cache is not working better. I also wish there would be an easy way to deselect all “Mark clip for render cache” from clips, so at least you could work in a short sequence.
    [Sascha Haber] “But you could render the whole thing using the “professional workflow””
    Are you referring to a specific workflow? any link?
    David Baud
    Post & VFX
    KOSMOS PRODUCTIONS
    Denver – Paris
