Activity › Forums › Adobe Premiere Pro › Render Bars and Performance Mac vs PC
  • Render Bars and Performance Mac vs PC
    Posted by Scott O’hara on July 2, 2016 at 6:36 am
    Hi All,
    I edit at work on a new Mac Pro model – 8 Core, 3.0 Ghz, 32 GB of memory, 1TB Flash storage, Dual AMD Firepro D700. Media is placed on a external RAID 5 connected via thunderbolt. Most of the time I don’t get a “red” render bar on top, especially if I’m matching the media with project settings. But even if I’m cutting Canon, Sony, or RED r3d files and previewing for Prores, most of it can be in real time and at most I get a “yellow” bar and pretty decent playback on 1/2 to full resolution. “Red” bars come into play when I’m adding color, effects, etc. or heavy multi-cam cuts. And when I do have to render the “red” bar for previewing, exports, etc. it goes pretty quick.
    Now I just purchased a Dell Precision 7910 and did some upgrades (memory,etc) – Dual 8 core Xeon, 2.4 GHz Turbo, 32GB of memory, 480GB SSD boot drive with internal RAID 0 created through BIOS for media. Graphics card is Nvidia NVS 310, 1GB. I’m going to be swapping out the NVS in the next month or so for a GeForce 1070. Now with the current PC setup (without new graphics card), I get a “red” bar for everything that isn’t matched (media & project settings). And when I render it takes several hours.
    My question is, what are the biggest factors that are creating this gap in performance? Is it the graphics card? I’m new to PC so I don’t know if I’m overlooking something. I do a lot of cutting with r3d 5k, etc. and haven’t had any real issues on the Mac. I’d like to get the PC to that level.
    Any thoughts/advice would be greatly appreciated.
    Scott O’hara replied 10 years, 3 months ago 2 Members · 2 Replies
  • Alex Udell
    July 2, 2016 at 11:20 am
    Hi….
    While Ppro’s mercury playback is the synergy of gpu, cpu, ram, and hard disk utilization….
    they heart of it is most definitely the GPU
    comparing the card you have:
    1/2 gig of texture memory and 48 cuda cores
    to the one you are getting:
    8gb texture memory with 1920 cuda cores….
    I’d say that for sure the GPU is a huge bottleneck in your system….particularly with the footage types you want to process.
    if you current configuration recognizes the GPU at all…I’d try disabling it (file>project settings) and see if you do any better….
    but yes….you will see a gain when you get the new card.
    hth,
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    Let’s Connect on Linkedin
    Examples: Retail Automotive Motion Graphics Spots
    Example: Customer Facing Explainer Video
    Example: Infotainment & Package editorial
  • Scott O’hara
    July 2, 2016 at 7:39 pm
    Hi Alex,
    Thanks for the feedback. Yeah that makes sense on the bottleneck. I was figuring it was the graphics card but wanted to make sure I wasn’t overlooking something else with the PC.
    Thanks again.
