Activity Forums VEGAS Pro render AVC?
  • render AVC?
    Posted by Joe Tavola on June 27, 2012 at 1:09 am
    I have shot video with a Sony HX1 camera, and below is the info on the video clip. If I want to render this and not lose any quality, which template would i use in Vegas 11 Pro? and what render settings in that template should be adjusted?
    I will be playing this off hardrive so i’m not looking to burn to dvd or bluray, i want to leave it in original format if possible and just play it off hardrive… reason why i want to render is that i will be editing a bunch of these clips, this one clip is an example of the video footage this camera shots in.
    General
    Complete name : D:2012-06-25MAH09153.MP4
    Format : MPEG-4
    Format profile : Sony PSP
    Codec ID : MSNV
    File size : 42.7 MiB
    Duration : 29s 529ms
    Overall bit rate : 12.1 Mbps
    Encoded date : UTC 2012-06-22 14:13:45
    Tagged date : UTC 2012-06-22 14:14:14
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate mode : Variable
    Bit rate : 12.0 Mbps
    Maximum bit rate : 16.0 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.258
    Stream size : 42.3 MiB (99%)
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format version : Version 4
    Format profile : LC
    Codec ID : 40
    Duration : 29s 525ms
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 462 KiB (1%)
    Joe Tavola replied 14 years, 2 months ago 4 Members · 9 Replies
  • 9 Replies
  • Andrey Sibiryakov
    June 27, 2012 at 9:05 am
    Using AVC you will lose quality in any case.
    But if you will choose the highest bitrates, you’ll have the semblance of the original quality.
    If you have enough space, use lossless sony YUV instead of avc.
  • Roger Bansemer
    June 27, 2012 at 2:50 pm
    I render shows we do for PBS in the Sony MXF format. Very high quality.
    A great player to use to view them is the free Sony XDcam viewer.
    Roger Bansemer
  • John Rofrano
    June 28, 2012 at 2:21 pm
    I would just render back to the original AVC format. Use the Sony AVC encoder with the AVCHD 1440×1080-60i template. This template matches your original format very closely (in fact it has a higher bit-rate so it should hold up very well)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Joe Tavola
    June 28, 2012 at 2:50 pm
    thanks John, that is what i will do! can you explain why i would choose the 60i template? does this relate to the 29.970fps my source files are in at all? i see the 50i template too, what’s the difference basically from 50i-60i?
  • Joe Tavola
    June 28, 2012 at 2:53 pm
    think i got the answer to my own question 50i = PAL and 60i=NTSC cool thanks again!
  • John Rofrano
    June 28, 2012 at 4:19 pm
    [Joe Tavola] “think i got the answer to my own question 50i = PAL and 60i=NTSC cool thanks again!”
    Yes, 29.97 frames per second equals 59.940 fields per second which is commonly abbreviated as 60i (~60 interlaced fields).
    ~jr
  • Joe Tavola
    July 5, 2012 at 6:23 pm
    n/m
  • John Rofrano
    July 5, 2012 at 8:13 pm
    [Joe Tavola] “my source files say progressive (mediainfo), is the 60i (interlaced)? would i not want them to stay at progressive, if so what should i choose when rendering in that template?”
    Sorry I didn’t catch that your video was progressive (it says so right in your original post). You should definitely change your project and the render template to be progressive as well.
    ~jr
  • Joe Tavola
    July 7, 2012 at 6:07 pm
    yup found it where i make the change in the template, thanks.
