Activity Forums Avid Media Composer Render after redigitize problem
  • Render after redigitize problem
    Posted by Jimmeeth on November 21, 2005 at 6:14 am
    My piece was originally digitized and edited at 20:1 resolution. I duplicated the sequence, performed a decompose and redigitized my footage at 2:1. Everything came in OK, but some of the clips will not re-render. It’s mainly clips with motion and/or superimposed effects plus the transitions in/out of them. When I click on them and render, it looks like it is happening but does not stick. The colored dot stays.
    What do you think I should do. Please help….
    Thanks. Jim
    German Rubio replied 20 years, 10 months ago 2 Members · 1 Reply
  • German Rubio
    November 23, 2005 at 11:09 am
    It happened to me.
    We use SCSI hard drives for digitize and OMF, and 2 IDE for the tgas and also other kind of footage.
    Maybe it would be that u have redigitize the clips on the other hard drives and then they cant make it play. Beacuse they are not so quick to support 2:1 resolution with effect.
    Try to redigitize the clips again on the SCSI drives if you have. If it still dont work, open the effect windows and try to render from the rendeer button over there, not the render in-out or render at position when you make a rightclilck on the timeline.
    If not, you have to find the original clip, and make the motion or speed effect again with the fit to fill option.
    Our problem was with the strobe motion.
    I would like to know wich avid and system do you have. It would be nice to know for try to solve the problem.
    Cu!!!!!
