Render
Posted by Dan Sherman on February 6, 2006 at 3:56 amTwenty minute project stops rendering after 4 minutes.
Low memory message appears.
Says shut down other applications.
Don’t have any others running.
Any suggestions on how to get this rendered?
Proejct is vide0 from one of those mini-disc camcorders, with stills and a music track.
Thankful for any suggestions.Dan Sherman replied 20 years, 8 months ago 4 Members · 15 Replies -
Chris Young
February 6, 2006 at 2:26 pmTry the following. Make sure under options/preferences/video that your ‘Dynamic RAM preview’ is set to 16MB, Ed’s suggestion and it really seems to work. This will avoid excessive page file size during renders plus it stops the runaway consumption of ram which seems to take place when large still images are involved with the render. Especially if those stills have very large pixel dimensions, in fact I find it best for anything over 720 x 480 or 720 x 576 if you are in PAL.
If that fails try rendering your timeline in segments and then stiching these segments together. You may find this works or you may find one segment render hangs Vegas. In which case you may have a corrupt graphic or other element in that segment. If that’s the case then it’s a process of elimination from there on in I’m afraid.
Chris Young
Sydney -
Edward Troxel
February 6, 2006 at 3:56 pm -
Dan Sherman
February 6, 2006 at 4:01 pmHey Chris,
Maximum dynamic ram is 550 MB under options/preferences/video.
You suggest 16 MB?
Must be looking in the wrong spot -
Edward Troxel
February 6, 2006 at 4:05 pm -
Dan Sherman
February 6, 2006 at 5:11 pmRender stopped again,—this time at 47 secons.
Message says;
“System low on memory. You may have to reduce memory usage by closing other applications”
But don’t have any other apps open. -
Dan Sherman
February 6, 2006 at 5:21 pmat 4:48 on timeline,—is a photo.
When opened in pac/crop this photo is grey-out.
I have run across a number of these.
Tha a clue? -
Dan Sherman
February 6, 2006 at 5:21 pmI stand corrected,—render stopped at 4:48 this time.
Tha a clue? -
Dan Sherman
February 6, 2006 at 5:28 pmReally getting wierd now.
Photo after the one where render stopped does not even show on preview when cursor passes over it.
As though it is not there! -
Peter Wright
February 7, 2006 at 12:37 amAre any of these photos on an external drive? It could be that a temporary loss of connection, firewire or USB2, is causing them to be unavailable.
