Activity › Forums › Apple Final Cut Pro Legacy › render
render
Posted by Travisl on September 20, 2007 at 6:31 pmis there a way that i can edit without having to render everytime i place a clip on the time line? i’m using RT,
Tom Meegan replied 18 years, 12 months ago 3 Members · 2 Replies -
Tom Wolsky
September 21, 2007 at 12:04 amYes. Make your sequence settings match exactly the settings of your media. Assuming you’re working with a file format that is editable in FCP.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop” -
Tom Meegan
September 21, 2007 at 12:09 amMatch sequence setting to clip settings.
Use an easy set up that matches your source footage, and you should be all good.
Final Cut Pro > Easy Set Up…
In FCP 6 the default behavior as you make your first edit into the sequence is to ask if you would like to change the sequence settings to match the clip settings. Say yes unless you have a good reason not to.
If you need to trouble shoot further:
Select a clip and hit Command – 9
Make note of the settings.
Select your sequence and hit Command – 0
Make these settings match the clip settings.
The water is a bit deep here
