Activity Forums Adobe Premiere Pro renaming corresponding clips in TL, project & finder in one go?
  • renaming corresponding clips in TL, project & finder in one go?
    Posted by Clermond Ferrand on September 17, 2012 at 2:20 pm
    hi, using two ore more AVCHD directories causes different files with identical names. One possibility is to rename before importing to Premiere e.g. via Bridge. But sometimes it makes more sense to rename files when they are in the timeline or you have to change naming again. Is there a way to rename the corresponding clip in the timeline, in the project & and in the finder in one go? I only found it step by step. Rename in the timeline -> show in project, rename & reassign -> show in finder, rename. Thanks for your time.
    Clermond Ferrand replied 14 years ago 1 Member · 0 Replies
  • 0 Replies
