Activity › Forums › Media 100 › Renaming Batch Export Items?
  • Renaming Batch Export Items?
    Posted by Jaeson Koszarsky on August 28, 2013 at 5:21 pm
    I have 20 ads in a single program. If I add each to the batch export, Media100 gives them all the same name. Can I rename the entries in the queue?
    Jaeson
    Jaeson Koszarsky replied 13 years, 1 month ago 2 Members · 2 Replies
  • Floh Peters
    August 29, 2013 at 4:35 pm
    Hmmm, if you want to do a batch export (range), you cannot do that in a single pass anyway, since the batch export window will look at your set range on your timeline when you press the “start” button in the export window, as far as I know…
  • Jaeson Koszarsky
    August 29, 2013 at 5:56 pm
    I wondered about that. It would be great if the queue item could remember the range that existed when it was added to the queue and be given a user-definable name.
    Jaeson
