Activity Forums Adobe After Effects Expressions Rename an effect and update expressions
  • Rename an effect and update expressions
    Posted by Romain Cousin on October 19, 2016 at 3:39 pm
    Hi!
    I am writing a script which
    1 – write an expression on every selected properties
    2 – create a null layer
    3 – create an effect on this null (expressions are linked to the properties of this effect)
    Problem :
    4 – At the end of the script I want to rename the effect on the null layer. To correct the expressions I use an “autoFixExpressions” but it doesn’t work…
    I think After effects doesn’t evaluate / refresh the expressions until the script is finished and “autoFixExpressions” need valid expressions at some point.
    Is there a way to force expressions to refresh before renaming my effect?
    Thank you!
    Romain Cousin replied 9 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
