Activity Forums Audio Removing white noise and hum when Audacity’s noise removal fails you?
  • Removing white noise and hum when Audacity’s noise removal fails you?
    Posted by Erin Herbst on January 7, 2015 at 8:27 pm
    I’ve got an audio clip from an interview I did recently that’s proving especially difficult to run noise-removal on in Audacity. We had to film it at a firestation with lots of background noise so I set my Tascam DR-60 recording levels to low when I recored her with a boom mic. Wish I hadn’t done that as now I have to amplify the track a ton just to hear her, which also amps up white-noise and humming. I’ve tried using Audacity’s noise removal feature but that ends up distorting her voice and it ends up sounding even worse.
    Does anyone have some tips for removing white-noise and hum in Audacity when the noise removal tool fails you?
    Here’s the track after being amplified: 8378_amplified.aiff.zip
    Same track after applying noise-removal: 8377_amplifiednoiseremoved.aiff.zip
    he first is the track amplified, the second is the amplified track after I’ve run noise removal.
    Trying to finish this project by Sunday so any advice is much appreciated!
    Matt Campbell replied 11 years, 8 months ago 3 Members · 3 Replies
  • Dwight Cook
    January 8, 2015 at 3:39 pm
    Hi, I listened to your interview and thought I would throw in my two cents. I find subtle processing is the key. I used iZotope RX2 denoiser and after sampling some hom/hiss at the rear of the file was able to reduce the noise.
    https://rcpt.hightail.com/2693232662/4d98e0f4b66548057fb75493744ef91d?cid=tx-02002208350200000000&s=19105
    Cheers
  • Erin Herbst
    January 8, 2015 at 8:23 pm
    Wow Dwight that is such an improvement! I’m downloading a trial of isotope now. Can you tell me what settings used (even just providing a screenshot would be fine) when you ran the denoiser?
    You’re a lifesaver. I really can’t thank you enough.
  • Matt Campbell
    January 27, 2015 at 8:10 pm
    What NLE do you use? Premiere Pro comes with Audition which does a pretty decent job with this. Audacity is good for freeware, but other pro apps will give you much greater control.
    Noise reduction isn’t always a good thing to use, it can often make things sound worse if you’re not careful. Try noise reduction with some EQ or notch filtering afterwards. You won’t be able to get rid of it, but you can def. reduce it.
    iMac 3.5 Ghz Intel Core i7
    16 GB of RAM, NVIDIA GeForce GTX 780M 4096 MB
    External RAID 5 in T-Bolt Chasis using eSata
    BMD Decklink Studio 2, FSI BM210, KRK Rokit 5s, Mackie 802
