Activity › Forums › Adobe After Effects › Removing tracking dots
  • Tero Ahlfors
    March 23, 2020 at 4:02 pm
    This is exactly why one would not use tracking markers. Have you tried keying them? Isolate the spot with a mask and try to key out only the orange. You could also try masking them out and then keying/masking only the hair back.
  • Łukasz Piątkowski Create COW Profile Image
    Łukasz Piątkowski
    March 24, 2020 at 1:12 pm
    I tried Key them but with no great results :/
  • Gerry Lindfield
    March 24, 2020 at 7:29 pm
    Hi Łukasz
    There are a few approaches but mine would be this:
    Firstly, duplicate the layer.
    On the top layer, isolate the orange markers with masks.
    Set the masks to subtract.
    Reposition this layer below until the masked area is green across the whole shot.
    Precompose the two layers and use keylight to key out the green.
    You will get holes in the resultant key where the markers cross the hair, so use roto brush or extract to repair.
    You could also just paint the markers the same colour, but whatever technique you will have to roto the hair at some point probably.
    Hope this helps
    Gerry
