Activity Forums VEGAS Pro removing static “clicks” from audio
  • removing static “clicks” from audio
    Posted by Gilles Gagnon on July 4, 2012 at 6:59 pm
    In a recording, a few clicks which sound like static somehow made their way into the recording file. I have now idea what caused it. I’m using an external Tascam US-122L as a recording device.
    No clicks when I record off my Desktop PC but they appear when recording on my laptop.
    But.. I digress. the question is… Is there a free plugin that can be used to remove these?
    Cheers,
    G
    Gilles
    Gilles Gagnon replied 14 years, 1 month ago 3 Members · 9 Replies
  • 9 Replies
  • John Rofrano
    July 4, 2012 at 9:58 pm
    [Gilles Gagnon] “Is there a free plugin that can be used to remove these?”
    Audacity has a click remover and it’s free (not a plug-in but an audio application). Sony Sound Forge also has a Click and Crackle remover as does iZotope RX2 with it’s DeClicker but they are not free.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Rofrano
    July 4, 2012 at 10:07 pm
    double post
  • Roger Bansemer
    July 5, 2012 at 11:37 am
    Another suggestion is to take a slice of audio on part of your video that is clean and paste it over the click. Of course that only works when there is no speaking going on. That has saved me many times.
    Recently I had a bad spot with some crackle that lasted only a second or two. The video was on a farm and I added a couple seconds of barking dog over that short section to camouflage the bad audio and it worked like a charm.
    Roger Bansemer
  • Gilles Gagnon
    July 5, 2012 at 11:49 am
    Thanks John,
    I loaded the latest version of Audacity last night, quickly tried but didn’t work. I’ll try again today while I tweak the settings of the de-clicker.
    It’s a good one to have in my toolbox regardless. Thanks for mentioning it.
    Gilles
    Gilles
  • Gilles Gagnon
    July 5, 2012 at 11:53 am
    Thanks Roger,
    In this case it’s someone signing so this may work. If I can’t get Audacity to remove the noise, I’ll use your trick. If I can isolate the click, which is barely visible even on an expanded waveform as it’s not a spike, I will cut it out and crossfade the resulting cut.
    Thanks.
    PS. I like the dogs barking overlay… clever.:)
    Gilles
  • Roger Bansemer
    July 5, 2012 at 3:34 pm
    If you are looking for a sound like the dog barking or any sound at all, you can most likely find it for free at:
    https://www.freesound.org
    I upload sounds there and everyone that does shares them royalty free. It’s a great resource.
    Roger Bansemer
  • Gilles Gagnon
    July 5, 2012 at 3:59 pm
    Thanks Roger,
    G
    Gilles
  • John Rofrano
    July 21, 2012 at 6:35 pm
    [Gilles Gagnon] “I loaded the latest version of Audacity last night, quickly tried but didn’t work.”
    Well… I guess it’s a case of “you get what you pay for”. 😉 If this is your livelihood, I would seriously consider investing in iZotope RX2. It is an amazing tool for fixing audio in post. You can download a free trial and see if it worked in your case before you buy.
    ~jr
  • Gilles Gagnon
    July 22, 2012 at 4:08 pm
    I understand John,
    In my case, it was just needed in this particular case doing some audio recording. I can usually clean it up using other methods.
    I’ll definitely purchase if the need increases.
    Thanks again,
    Gilles
    Gilles
