Activity › Forums › Adobe Audition › removing reular repeating little noise
  • removing reular repeating little noise
    Posted by Derrick on September 20, 2005 at 3:44 pm
    Hi there all,
    please could someone tell me if it is possible to remove this small thump sound in this WAV file. I’ve got access to Adobe Audition 1.5.
    I’ve tried many things, but perhaps someone else could help me?
    the problem is this sound happens freq. (every couple of seconds) in a 1 hour recording, and sometimes while dialog is spoken.
    http://www.malagold.co.za/Test.wav (2.13 MB).
    Thanks for any replies,
    Derrick
    Willie Toth replied 21 years ago 2 Members · 1 Reply
  • Willie Toth
    September 20, 2005 at 5:02 pm
    Derrick,
    Try noise removal check out the tutorial from Aug it will give you the perceedure … Where there isn’t any voice you can get rid of it by simply by amplifying -300 db … When I get home tonight I will see if I can come up with a setting that will work … When using the noise removal take it out in small increments starting at 60%, then 50% and so on, you will know when you have gone too far ……………… WILLIE
