Activity › Forums › Adobe Premiere Pro › Removing Repeated Frames in Video
  • Removing Repeated Frames in Video
    Posted by Amila Kumarasinghe on January 9, 2015 at 5:02 pm
    Hi, I’m independent film maker from sri lanka. I have a problem with iphone 6plus 240fps video.
    briefly its like this.
    When i record a slow motion video on 240fps mode, after import it to premier or AE or FCP or any platform, i can confirm (interpret) that 240fps footage to 24p. (like slow down 10%)
    After confirm it to 24fps, in 24p timeline, there is a repeated frame after every x16th frame. that mean like this
    1 2 3 4 5 6 7 8 9 10 11 12 13 14 16 “16repeated frame” 17 18 19 …etc
    so when i shoot a video for few minutes, it will automatically recorded a repeated frame after x16th frame in the video.
    Is there any possibility to analyse and remove those repeated frames in the video? (In AE or Pr or Avid or any platform or any encoder)
    Because removing one by one frame is pain in ass when the footage is so long.
    hope you guys can help me.
    Thank you.
    3D Animator
    VisualEffects Compositor
    D.P / Cinematographer and Editor
    Amila Kumarasinghe replied 11 years, 8 months ago 3 Members · 6 Replies
  • Amila Kumarasinghe
    January 9, 2015 at 6:14 pm
    Accidently clicked solution found flag.
    Pls reply here because i still need the solution
    Independent Film maker
    Motion Graphics Designer
  • Tero Ahlfors
    January 9, 2015 at 7:25 pm
    That shouldn’t be the case if the footage is exactly 240fps. I’d guess on previous experience with iPhone stuff that the footage has a variable frame rate so slowing it down might do that. It would probably work better if you set the file to run at 24fps in the interpret footage settings.
  • Trevor Asquerthian
    January 9, 2015 at 10:12 pm
    AE – https://aescripts.com/duplicate-frame-remover/
    Worked a treat for a similar issue I had
    January 10, 2015 at 5:06 am
    Hi, i cheeked also with the Filmic pro app. it records naively 240fps constant and in higher bit-rate also. still the problem is there 🙁
    January 10, 2015 at 5:09 am
    I thought to purchase it too. is that worth to purchase it and the problem you got solved? whats your issue you had actually?
    January 10, 2015 at 7:10 am
    Hi, just downloaded the script file. Awesome. it worked great. Thank you very much for the support 😀
